Should paint it something other than black. Something like the new commodore green
Tiddys Dak Dak corner
Started by Tiddy, Jun 09 2010 09:48 PM
#121
Posted 19 January 2011 - 05:07 PM
#122
Posted 30 January 2011 - 06:58 PM
#123
Posted 15 May 2011 - 01:22 AM
Made
277hp athubs
360nm athubs
With dccd on lock, 50/50 power split.
Standard 2 litre, standard boost, standard everything.
No tune.
Spec C goodness!!
I made approx 300 with another 6 psi and a bit of timing...
Not getting a tune for a bit, running til summer to iron out the huge amount of bugs the car has.
Then motec and blocking off the avcs on the heads
Adjustable cam wheels, 272 cams, nitrated 2.5 crank redrilled, je pistons to get the clearance back, standard 2.5 rods.
Effectively a 2.2
TD06 twin scroll huffer, genuine trust twinscroll.
277hp athubs
360nm athubs
No tune.
Spec C goodness!!
Effectively a 2.2
98 STi Twinscrollin
#124
Posted 15 May 2011 - 11:43 AM
#125
Posted 15 May 2011 - 04:11 PM
Been watching the build up on FB, looking forward to seeing it finished!
Posted 15 May 2011 - 04:31 PM
Most certainly coming along nicely.
Pay attention Trevor!
i dont think i have callum's kind of patience. i just need a ecu and tune so i can go fast now
skyline... rex... skyline... rex... im starting to sense a pattern
#127
Posted 16 May 2011 - 12:46 PM
Fuel setup,
Walbro intank pump feeding a 2 litre surge tank, out of that into a bosch 044 which feeds the motor.
Standard spec c parallel rails and pink sti 550 injectors.
Will change injectors when its tuned or simply de-cap and hi flow them to 816cc.
98 STi Twinscrollin
