Tiddys Dak Dak corner
#101
Posted 09 January 2011 - 11:08 PM
Posted 10 January 2011 - 12:04 AM
But clutch in and there was no rattle.
Its gone away now, not sure what caused it.
#103
Posted 10 January 2011 - 04:49 AM
#104
Posted 10 January 2011 - 11:23 AM
Motor is out.
Gotta pull out the gearbox and diff, remove coilovers to get rebuilt and basically get the car back to a shell.
#105
Posted 10 January 2011 - 01:14 PM
Posted 10 January 2011 - 06:08 PM
Yeah, that's a thrust bearing. When the clutch is disengaged (pedal in), there is no load on the bearing so it's quiet. As soon as load is placed on it, that's when the noise comes. The opposite is a gearbox bearing, which is what I have now. Cbf pulling the box out though, cos it's only very minor.
Nup. Wrong way around. When you put your foot into the clutch it pushes the bearing onto the pressure plate fingers (diaphragm) which declamps the clutch plate. That's when the thrust bearing is noisy.
Most of the time it's the input shaft when you take your foot off the clutch.
I thought you were an apprentice mechanic man, you should know this.
#107
Posted 10 January 2011 - 06:16 PM
#108
Posted 10 January 2011 - 06:26 PM
Lol don´t worry Rhys, you can always go work at KYP... They also told me it was a thrust bearing
In any case, was told it´s not really anything to worry about?
#109
Posted 10 January 2011 - 06:31 PM
#110
Posted 10 January 2011 - 07:35 PM
Cos I'm perfect in every possible way, and no everything about everything.
Ffs, we all make mistakes.
Posted 10 January 2011 - 07:54 PM
#112
Posted 10 January 2011 - 08:09 PM
Posted 10 January 2011 - 08:13 PM
#114
Posted 10 January 2011 - 08:59 PM
Version 8 STI with low kms, freshen up bottom end and work the heads
New linkages for the 6 speed(short shift)
Cusco centre differential controller.
http://cgi.ebay.com/...sQ5fAccessories
BRAKES
http://www.project-m...cali_f6slim.php
REAR DIFF-1.5 WAY
http://www.kaazusa.com/lsd_subaru.html
Cosworth Oil Pump
Cosworth Oil Baffle
Cosworth Forged Pistons (92mm)
Cosworth Fully Counterweighted Forged Crankshaft (79mm)
Cosworth Forged Connecting Rods
Cosworth Rod Bearings
Cosworth Main Bearings
Cosworth Piston Rings
http://www.cosworth....aspx?id=1113468
Cams
Subaru EJ20 (2.0L) Set of four (NON-AVCS Type from 2000 to 2005)
"272" deg. 10mm lift
Highflowed heads, exhaust and intake ports enlarged
Unsure on valves so far.
Price so far ~12k
#115
Posted 10 January 2011 - 11:38 PM
#116
Posted 11 January 2011 - 12:19 AM
#117
Posted 11 January 2011 - 12:41 AM
I thought you were waiting to go with whatever your tuner recommended???
#118
Posted 11 January 2011 - 06:41 AM
#119
Posted 11 January 2011 - 06:43 AM
Plus labour to disassemble the 2 litre block, insert kit and reassemble im probably looking at 5-7 grand, for the sake of 0.2L
Sean "GTRETA" has just a stock 2 litre bottom end and runs low 10s.
May stay 2 litre, Getting alot of feedback about the rings going on the cosworth kits.
The alternative is a HKS kit but I cant find much feedback on them.
Cams I can get are
272' intake 272' exhaust, 10mm lift from cosworth- $1500
264/264 with 9.4mm -$1500
depends how lumpy I want it, leaning towards 272 bit requires machining of the heads as AVCS will have to be deleted.
Will be looking into Kelford cams shortly.
Getting the motor and box with loom and ecu to my door from canada is costing me 750, which i thought was pretty keen! 6k for the cut itself with 31,00kms on it. 05 STI.
Getting the car back to a rolling shell at the moment and will be sending off for paint soon. Black is the colour of choice.
#120
Posted 12 January 2011 - 12:07 AM
http://www.turbobyga...R_700382_12.htm
Also looking into HTA, FP GREEN, GTPUMPS. Not going IHI this time.
Externally gated
