Milage:67,000km (34 on nismo dash, had it swapped) (7000km on forged engine)
Year: 1989
Transmission:Manual
Colour: Gun Metal Grey
Currently registered? 6 Months rego.
ENGINE AND DRIVE TRAIN
Sydney Kid RB26 build (do a search on skylines australia forums, well known builder) including
8.8 to 1 compression ratio
ACL 86mm Forged pistons
Eagle H Beam forged rods
ARP Rod Bolts
ACL rings
ARP head studs
ARP main bearing studs
600HP Head work
Stainless Steel Exhaust Valves
Adjustable Cam Gears (set to standard at the moment, heaps more bottom end there to be dialed in)
Balanced rotating mass
Sump Extension - Extra few Litres with full baffles
HKS 2530 Turbos
700cc 12A Turbo Injectors
80mm AFM's
Apexi Power FC with Hand Controller
Apexi AVCR Electronic Boost Controller
K&N Pod Filters
HKS Billet Flywheel
HKS Twin plate rebuilt by Jim Berry
Full Redline Racing oils except engine, which has Royal purple changed on the 26/3/2010.
Ceramic coated exhaust manifolds, turbine housing, dump pipes and Y pipes (Big $$!!)
Bosch 044 Race Fuel Pump
N1 oil pump
New cambelt pulleys
Wide oil pump drive flange
Oil flow restrictors
New Cambelt
Block O’rings
Custom Stainless Catback Exhaust
New Radiator
Iridium Plugs
WHEELS
17X9" +20 Sparco Racing Lightweight 5 Spoke rims
Near New Rubber all round (Toyo Proxe)
SUSPENSION
Full Sydney Kid Bilstein set up
Bilstein front and rear
King Coils
Whiteline Sway Bar (To be installed, have got it + mounts)
Front Strut Bar
Rear Strut Bar
BRAKES
Slotted Brake Rotors All Round
Bendix Pads
MISC
Autowatch alarm system.
Alpine stereo - MB Quart splits up front and Eclipse in the rear, powered by an Eclipse amplifier. (Sounds great)
Defi link Gauges with control unit II - Exhaust Temp (needs new probe/sensor), Oil Temp, Water Temp, Fuel Pressure. (Cost a fortune.....)
Original GTR Floor Mats
Currently as is, made 370rwhp on Hyperdrive's dyno (20psi). With cams dialed in and more boost, it would see 400++ easily. I don't care if your mate can pick up a 32gtr with 800hp for 16k with huge damage. This car won't blow up on you. It is as solid as they come.
It is a seriously clean and straight car. Has 1 minor rust spot about thumb nail size at the bottom of the rear window. Engine build cost $18k (had it sent over east to be built especially by Sydney Kid). (Have full build pics) Things like defi's are 350 per gauge etc. Tonnes has been spent. I'm only selling cause it doesn't get used and is in storage.
You won't find a better R32 GTR for the money. I believe KMS are accurate. Just check out the original parts such as steering wheel and pedals. It was built to look standard and even the engine bay looks stock. (The wheels were a bit of fun as well as being super lightweight) (No cop hassles). Have many many pictures.. You won't be disappointed.
Please no time wasters. I don't live where the GTR is stored so serious buyers only.
$26k.
