Disc Brakes Explained
No replies to this topic
The disc brake or disk brake is a device for slowing or stopping the rotation of a wheel. A brake disc (or rotor in U.S. English), usually made of cast iron or ceramic composites (including carbon, Kevlar and silica), is connected to the wheel and/or the axle. To stop the wheel, friction material in the form of brake pads (mounted on a device called a brake calliper) is forced mechanically, hydraulically, pneumatically or electromagnetically against both sides of the disc. Friction causes the disc and attached wheel to slow or stop. Brakes (both disc and drum) convert friction to heat, but if the brakes get too hot, they will cease to work because they cannot dissipate enough heat.
History
Disc-style brakes development and use began in England in the 1890s. The first calliper-type automobile disc brake was patented by Frederick William Lanchester in his Birmingham, UK factory in 1902 and used successfully on Lanchester cars. However, the limited choice of metals in this period, meant that he had to use copper as the braking medium acting on the disc. The poor state of the roads at this time, no more than dusty, rough tracks, meant that the copper wore quickly making the disc brake system non-viable (as recorded in The Lanchester Legacy). It took another half century for his innovation to be widely adopted.
Modern-style disc brakes first appeared on the low-volume Crosley Hotshot in 1949, although they had to be discontinued in 1950 due to design problems. Chrysler's Imperial also offered a type of disc brake from 1949 through 1953, though in this instance they were enclosed with dual internal-expanding, full-circle pressure plates. Reliable modern disc brakes were developed in the UK by Dunlop and first appeared in 1953 on the Jaguar C-Type racing car. The Citroën DS of 1955, with powered inboard front disc brakes, and the 1956 Triumph TR3 were the first European production cars to feature modern disc brakes. The first production car to feature disc brakes at all 4 corners was the Austin-Healey 100S in 1954. The first British company to market a production saloon fitted with disc brakes to all four wheels was Jensen Motors Ltd with the introduction of a Deluxe version of the Jensen 541 with Dunlop disc brakes. The next American production cars to be fitted with disc brakes were the 1963 Studebaker Avanti (optional on other Studebaker models), standard equipment on the 1965 Rambler Marlin (optional on other AMC models), and the 1965 Chevrolet Corvette Stingray (C2).
Disc brakes offer better stopping performance than comparable drum brakes, including resistance to "brake fade" caused by the overheating of brake components, and are able to recover quickly from immersion (wet brakes are less effective). Unlike a drum brake, the disc brake has no self-servo effect and the braking force is always proportional to the pressure placed on the braking pedal or lever.
Many early implementations for automobiles located the brakes on the inboard side of the driveshaft, near the differential, but most brakes today are located inside the road wheels. (An inboard location reduces the unsprung weight and eliminates a source of heat transfer to the tires, important in Formula One racing.)
Disc brakes were most popular on sports cars when they were first introduced, since these vehicles are more demanding about brake performance. Discs have now become the more common form in most passenger vehicles, although many (particularly light weight vehicles) use drum brakes on the rear wheels to keep costs and weight down as well as to simplify the provisions for a parking brake. As the front brakes perform most of the braking effort, this can be a reasonable compromise.
Discs
The design of the disc varies somewhat. Some are simply solid cast iron, but others are hollowed out with fins or vanes joining together the disc's two contact surfaces (usually included as part of a casting process). This "ventilated" disc design helps to dissipate the generated heat and is commonly used on the more-heavily-loaded front discs.
Many higher performance brakes have holes drilled through them. This is known as cross-drilling and was originally done in the 1960s on racing cars. Brake pads will outgas and under use may create boundary layer of gas between the pad and the disc hurting braking performance. Cross-drilling was created to provide the gas someplace to escape. Although modern brake pads seldom suffer from out gassing problems, water residue may build up after a vehicle passes through a puddle and impede braking performance. For this reason, and for heat dissipation purposes, cross drilling is still used on some braking components, but is not favoured for racing or other hard use as the holes are a source of stress cracks under severe conditions.
Discs may also be slotted, where shallow channels are machined into the disc to aid in removing dust and gas. Slotting is the preferred method in most racing environments to remove gas, water, and de-glaze brake pads. Some discs are both drilled and slotted. Slotted discs are generally not used on standard vehicles because they quickly wear down brake pads, however this removal of material is beneficial to race vehicles since it keeps the pads soft and avoids vitrification of their surfaces.
On the road, drilled or slotted discs still have a positive effect in wet conditions because the holes or slots prevent a film of water building up between the disc and the pads. Cross drilled discs may eventually crack at the holes due to metal fatigue. Cross-drilled brakes that are manufactured poorly or subjected to high stresses will crack much sooner and more severely.
Disc brake discs are commonly manufactured out of a material called grey iron. The SAE maintains a specification for the manufacture of grey iron for various applications. For normal car and light truck applications, the SAE specification is J431 G3000 (superseded to G10). This specification dictates the correct range of hardness, chemical composition, tensile strength, and other properties necessary for the intended use.
Historically, brake discs were manufactured throughout the world with a strong concentration in Europe, and America. Between 1989 and 2005, manufacturing of brake discs is migrating predominantly to China.
Racing
In racing and very high performance road cars, other disc materials have been employed. Reinforced carbon discs and pads inspired by aircraft braking systems were introduced in Formula One by Brabham in conjunction with Dunlop in 1976. Carbon-Carbon braking is now used in most top-level motorsport worldwide, reducing unsprung weight, giving better frictional performance and improved structural properties at high temperatures, compared to cast iron. Carbon brakes have occasionally been applied to road cars, by the French Venturi sports car manufacturer in the mid 1990s for example, but need to reach a very high operating temperature before becoming truly effective and so are not well suited to road use.
Ceramic Composites
The first development of the modern ceramic brake was made by British Engineers working in the railway industry for TGV applications in 1988. The objective was to reduce weight, the number of brakes per axle, as well as provide stable friction from very high speeds and all temperatures. The result was a carbon fibre reinforced ceramic process which is now used in various forms for automotive, railway, and aircraft brake applications.
The requirement for a large section of ceramic composite material having very high heat tolerance and mechanical strength often relegates ceramic discs to exotic vehicles where the cost is not prohibitive to the application, and industrial use where the ceramic disc's light weight and low maintenance properties justify the cost relative to alternatives. Composite brakes can withstand temperatures that would make steel discs bendable.
Disc Damage Modes
Discs are usually damaged in one of four ways, warping, scarring, cracking, or excessive rusting. Service shops will sometimes respond to any disc problem by changing out the discs entirely, This is done mainly where the cost of a new disc may actually be lower than the cost of labour to resurface the original disc. Mechanically this is unnecessary unless the discs have reached manufacturer's minimum recommended thickness, which would make it unsafe to use them, or vane rusting is severe (ventilated discs only). Most leading vehicle manufacturers recommend brake disc skimming as a solution for lateral run-out, vibration issues and brake noises. The machining process is performed in a brake lathe, which removes a very thin layer off the disc surface to clean off minor damage and restore uniform thickness. Machining the disc as necessary will maximise the mileage out of the current discs on the vehicle.
Warping
Warping is often caused by excessive heat. When the disc's friction area is at a substantially higher temperature than the inner portion (hat) the thermal expansion of the friction area is greater than the inner portion and warping occurs. This can be minimized by using "floating" rotors which decouple the friction area from the inner portion and allow thermal expansion to occur at different rates. Primary causes of overheating include undersized or excessively machined brake discs, excessive braking (racing, descending hills/mountains), "riding" the brakes, or a "stuck" brake pad (pad contacts the disc at all times).
Measuring warping is accomplished using a dial indicator on a fixed rigid base, with the tip perpendicular to the brake rotor's face. It is typically measured about 12 mm from the outside diameter of the rotor. The rotor is spun. The difference between minimum and maximum value on the dial is called lateral run out. Typical hub/rotor assembly run out specifications for passenger vehicles are around 0.0020" or 50 micrometres. Run out can be caused either by deformation of the disc itself or by run out in the underlying wheel hub face or by contamination between the rotor surface and the underlying hub mounting surface. Determining the root cause of the indicator displacement (lateral run out) requires disassembly of the rotor from the hub. Rotor face run out due to hub face run out or contamination will typically have a period of 1 minimum and 1 maximum per revolution of the brake rotor.
Another cause of warping is when the disc is overheated and the vehicle is stopped with the brakes continuously applied. In such a case, the area where the pads are in contact with the disc will cause uneven cooling and lead to warping.
Incorrect fitting also leads to many cases of warping, the disc's retaining bolts (or the wheel/lug nuts, if the disc is simply sandwiched in place by the wheel, as on many cars) must be tightened progressively and evenly. The use of air tools to fasten lug nuts is extremely bad practice, unless a torque tube is also used. The vehicle manual will indicate the proper pattern for tightening as well as a torque rating for the bolts. Lug nuts should never be tightened in a circle. Some vehicles are sensitive to the force the bolts apply and tightening should be done with a torque wrench.
Several methods can be used to avoid overheating brake discs. Use of a lower gear when descending steep grades to obtain engine braking will reduce the brake loading. Also, operating the brakes intermittently, braking to slower speed for a brief time then coasting will allow the brake material to cool between applications. Riding the brakes lightly will generate a great amount of heat with little braking effect and should be avoided. High temperature conditions as found in automobile racing can be dealt with by proper pad selection, but at the trade-off of everyday driveability. Pads that can take high heat usually do best when hot and will have reduced braking force when cold. Also, high heat pads typically have more aggressive compounds and will wear discs down more quickly. Brake ducting that forces air directly onto the brake discs, common in motorsports, is highly effective at preventing brake overheating. This is also useful for cars that are driven both in motorsports and on the street, as it has no negative effect on driveability. A further extension of this method is to install a system which mists the discs with water. Jaguar has reported great reductions in disc temperatures with such a system.
Warping will often lead to a thickness variation of the disc. If it has run out, a thin spot will develop by the repetitive contact of the pad against the high spot as the disc turns. When the thin section of the disc passes under the pads, the pads move together and the brake pedal will drop slightly. When the thicker section of the disc passes between the pads, the pads will move apart and the brake pedal will raise slightly, this is pedal pulsation. The thickness variation can be felt by the driver when it is approximately 0.17 mm or greater (on automobile rotors).
Not all pedal pulsation is due to warped discs. Brake pad material operating outside of its designed temperature range can leave a thicker than normal deposit in one area of the disc surface, creating run-out due to a "sticky" or "hotspot" that will grab with every revolution of the disc. Grease or other foreign materials can create a slippery spot on the disc, also creating pulsation.
Rotors can be machined to eliminate thickness variation and lateral run out. Machining can be done in-situ (on-car) or off-car (bench lathe). Both methods will eliminate thickness variation. Machining on-car with proper equipment can also eliminate lateral run out due to hub-face non-perpendicularity.
Scarring
Scarring can occur if brake pads are not changed promptly when they reach the end of their service life and are considered worn out. Once enough of the friction material has worn away, the pad's steel backing plate (for glued pads) or the pad retainer rivets (for riveted pads) will bear directly upon the rotor's wear surface, reducing braking power and making scratches on the disc. Generally a moderately scarred/scored rotor, which operated satisfactorily with existing brake pads, will be equally usable with new pads. If the scarring is deeper but not excessive, it can be repaired by machining off a layer of the disc's surface. This can only be done a limited number of times as the disc has a minimum rated safe thickness. The minimum thickness value is typically cast into the disc rotor during manufacturing on the hub of the rotor or on the edge of the disc in the USA.
To prevent scarring, it is prudent to periodically inspect the brake pads for wear. A tire rotation is a logical time for inspection, since rotation must be performed regularly based on vehicle operation time and all wheels must be removed, allowing ready visual access to the brake pads. Some types of alloy wheels and brake arrangements will provide enough open space to view the pads without removing the wheel. When practical, pads that are near the wear-out point should be replaced immediately, as complete wear out leads to scarring damage and unsafe braking. Many disc brake pads will include some sort of soft steel spring or drag tab as part of the pad assembly, which is designed to start dragging on the disc when the pad is nearly worn out. The result is a moderately loud metallic squealing noise, alerting the vehicle user that service is required, and this will not normally scar the disc if the brakes are serviced promptly. A set of pads can be considered for replacement if the thickness of the pad material is the same or less than the thickness of the backing steel.
Cracking
Cracking is limited mostly to drilled discs, which may develop small cracks around edges of holes drilled near the edge of the disc due to the disc's uneven rate of expansion in severe duty environments. Manufacturers that use drilled discs as OEM typically do so for two reasons, appearance, if they determine that the average owner of the vehicle model will prefer the look while not overly stressing the hardware, or as a function of reducing the unsprung weight of the brake assembly, with the engineering assumption that enough brake disc mass remains to absorb racing temperatures and stresses. A brake disc is a heat sink, so removing mass increases the heat stress it will have to contend with. Small hairline cracks may appear in any cross drilled metal disc as a normal wear mechanism, but in the severe case the disc will fail catastrophically. No repair is possible for the cracks, and if cracking becomes severe, the disc rotor must be replaced.
Rusting
The discs are commonly made from cast iron and a certain amount of surface rust is normal. The disc contact area for the brake pads will be kept clean by regular use, but a vehicle that is stored for an extended period can develop significant rust in the contact area that may reduce braking power for a time until the rusted layer is worn off again. Over time, vented brake rotors may develop severe rust corrosion inside the ventilation slots, compromising the strength of the structure and necessitating replacement.
Callipers
The brake calliper is the assembly which houses the brake pads and pistons. The pistons are usually made of aluminium or chrome-plated steel. There are two types of callipers, floating or fixed. A fixed calliper does not move relative to the disc. It uses one or more pairs of opposing pistons to clamp from each side of the disc, and is more complex and expensive than a floating calliper. A floating calliper (also called a "sliding calliper") moves with respect to the disc, along a line parallel to the axis of rotation of the disc. A piston on one side of the disc pushes the inner brake pad until it makes contact with the braking surface, then pulls the calliper body with the outer brake pad so pressure is applied to both sides of the disc.
Floating calliper (single piston) designs are subject to sticking failure, which can occur due to dirt or corrosion entering at least one mounting mechanism and stopping its normal movement. This can cause the pad attached to the calliper to rub on the disc when the brake is not engaged, or cause it to engage at an angle. Sticking can occur due to infrequent vehicle use, failure of a seal or rubber protection boot allowing debris entry, dry-out of the grease in the mounting mechanism and subsequent moisture incursion leading to corrosion, or some combination of these factors. Consequences may include reduced fuel efficiency, excessive wear on the affected pad, and friction-induced heat warping of the disc.
Pistons And Cylinders
The most common calliper design uses a single hydraulically actuated piston within a cylinder, although high performance brakes use as many as twelve. Modern cars use different hydraulic circuits to actuate the brakes on each set of wheels as a safety measure. The hydraulic design also helps multiply braking force. The number of pistons in a calliper is often referred to as the number of 'pots', so if a vehicle has 'six pot' callipers it means that each calliper houses six pistons.
Brake failure can occur due to failure of the piston to retract, this is usually a consequence of not operating the vehicle during a time that it is stored outdoors in adverse conditions. On high mileage vehicles the piston seals may leak, which must be promptly corrected.
Brake Pads
The brake pads are designed for high friction with brake pad material embedded in the disc in the process of bedding while wearing evenly. Although it is commonly thought that the pad material contacts the metal of the disc to stop the car, the pads work with a very thin layer of their own material and generate a semi-liquid friction boundary that creates the actual braking force. Of course, depending on the properties of the material, disc wear rates may vary. The properties that determine material wear involve trade-offs between performance and longevity.
The brake pads must usually be replaced regularly (depending on pad material), and most are equipped with a method of alerting the driver when this needs to take place. Some have a thin piece of soft metal that rubs against the disc when the pads are too thin, causing the brakes to squeal, while others have a soft metal tab embedded in the pad material that closes an electric circuit and lights a warning light when the brake pad gets thin. More expensive cars may use an electronic sensor.
Although almost all road-going vehicles have only two brake pads per calliper, racing callipers utilize up to six pads, with varying frictional properties in a staggered pattern for optimum performance.
Early brake pads (and linings) contained asbestos. When working on an older car's brakes, care must be taken not to inhale any dust present on the calliper (or drum). Although newer pads can be made of exotic materials like ceramics, Kevlar and other plastics, care to avoid inhalation of brake dust produced during operation should still be practiced no matter what materials are employed.
Brake Squeal
Sometimes a loud noise or high pitch squeal occurs when the brakes are applied. Most brake squeal is produced by vibration (resonance instability) of the brake components, especially the pads and discs (known as force-coupled excitation). This type of squeal should not negatively affect brake stopping performance. Simple techniques like adding chamfers to linings, greasing or gluing the contact between calliper and the pads (finger to back plate, piston to back plate), bonding insulators (damping material) to pad back plate, inclusion of a brake shim between the brake pad and back plate, etc. may help to reduce squeal. Cold weather combined with high early morning humidity (dew) often makes brake-squeal worse, although the squeal stops when the lining reaches regular operating temperatures. Dust on the brakes may also cause squeal, there are many commercial brake cleaning products that can be used to remove dust and contaminants. Finally, some lining wear indicators are also designed to squeal when the lining is due for replacement.
Overall brake squeal can be annoying to the vehicle passengers, passers-by, pedestrians, etc. especially as vehicle designs become quieter. Noise, vibration, and harshness (NVH) are among the most important priorities for today's vehicle manufacturers.
Apart from noise generated from squeal, brakes may also develop a phenomenon called brake judder or shudder.
Brake Judder
Brake judder is usually perceived by the driver as minor to severe vibrations transferred through the chassis during braking.
The judder phenomenon can be classified into two distinct subgroups, hot (or thermal), or cold Judder.
Hot judder is usually produced as a result of longer, more moderate braking from high speed where the vehicle does not come to a complete stop. It commonly occurs when a motorist decelerates from speeds of around 120 km/h to about 60 km/h, which results in severe vibrations being transmitted to the driver. These vibrations are the result of uneven thermal distributions, or hot spots. Hot spots are classified as concentrated thermal regions that alternate between both sides of a disc that distort it in such a way that produces a sinusoidal waviness around its edges. Once the brake pads (friction material/brake lining) comes in contact with the sinusoidal surface during braking, severe vibrations are induced, and can produce hazardous conditions for the person driving the vehicle.
Cold judder, on the other hand, is the result of uneven disc wear patterns or DTV (disc thickness variation). These variations in the disc surface are usually the result of extensive vehicle road usage. DTV is usually attributed to the following causes, waviness of rotor surface, misalignment of axis (run out), elastic deflection, thermal distortion, wear and friction material transfers.
Brake Dust
When braking force is applied, small amounts of material are gradually ground off the brake pads. This material is known as "brake dust" and a fair amount of it usually deposits itself on the braking system and the surrounding wheel. Brake dust can badly damage the finish of most wheels if not washed off. Airborne brake dust is known to be a health hazard, so most repair manuals recommend the use of a chemical 'brake cleaner' instead of compressed air to remove the dust. Different brake pad formulations create different amounts of dust, and some formulations, particularly metallic brake pads, are much more damaging than others. Ceramic brake pads contain significantly fewer metal particles, and therefore produce less corrosion of surrounding metal parts.
