An intercooler, or charge air cooler, is an air-to-air or air-to-liquid heat exchange device used on turbocharged and supercharged (forced induction) internal combustion engines to improve their volumetric efficiency by increasing intake air charge density through nearly isobaric (constant pressure) cooling. A decrease in air intake temperature provides a denser intake charge to the engine and allows more air and fuel to be combusted per engine cycle, increasing the output of the engine.
Intercoolers can vary dramatically in size, shape, and design, depending on the performance and space requirements of the entire supercharger system. Common spatial designs are front mounted intercoolers (FMIC), top mounted intercoolers (TMIC), hybrid mount intercoolers (HMIC), and side mount intercoolers (SMIC). Each type can be cooled with an air-to-air system, air-to-liquid system, or a combination of both.
Applications To Forced Induction
Turbochargers and superchargers are engineered to force more air mass into an engine's intake manifold and combustion chamber. Intercooling is a method used to compensate for heating caused by supercharging, a natural by-product of the semi-adiabatic compression process. Increased air pressure can result in an excessively hot intake charge, significantly reducing the performance gains of supercharging due to decreased density. Increased intake charge temperature can also increase the cylinder combustion temperature, causing detonation, excessive wear, or heat damage to an engine block.
Passing a compressed and heated intake charge through an intercooler reduces its temperature (due to heat rejection) and pressure (due to flow restriction of fins). If properly engineered, the net result is an increase in density. This increases system performance by recovering some losses of the inefficient compression process by rejecting heat to the atmosphere. Additional cooling can be provided by externally spraying a fine mist onto the intercooler surface, or even into the intake air itself, to further reduce intake charge temperature through evaporative cooling.
Intercoolers that exchange their heat directly with the atmosphere are designed to be mounted in areas of an automobile with maximum air flow. These types are mainly mounted in front mounted systems (FMIC). Cars such as the Nissan Skyline GT-R, Saab, Volvo 200 Series Turbo, Volvo 700 Series (and 900 series) turbo, Dodge SRT-4, 1st gen Mazda MX-6, Mitsubishi Lancer Evolution and Chevrolet Cobalt SS all use front mounted intercooler(s) mounted near the front bumper, in line with the car's radiator.
Many older turbo-charged cars, such as the Toyota Supra (JZA80 only), Nissan 300ZX Twin Turbo, Nissan 200SX (S13/14/14a/15), Mitsubishi 3000gt, Saab 900, Volkswagen, Audi TT, and Turbo Mitsubishi Eclipse use side-mounted air-to-air intercoolers (SMIC), which are mounted in the front corner of the bumper or in front of one of the wheels. Side-mounted intercoolers are generally smaller, mainly due to space constraints, and sometimes two are used to gain the performance of a larger, single intercooler. Cars such as the Subaru Impreza WRX, MINI Cooper S, Toyota Celica GT-Four, Nissan Pulsar GTI-R, Mazdaspeed3, Mazdaspeed6, and the PSA Peugeot Citroën turbo diesels, use air-to-air top mounted intercoolers (TMIC) located on top of the engine. Air is directed through the intercooler through the use of a hood scoop. In the case of the PSA cars the air intake is the grille above the front bumper, then flows through under-hood ducting. Top mounted intercoolers sometimes suffer from heat diffusion due to proximity with the engine, warming them and reducing their overall efficiency. Some World Rally Championship cars use a reverse-induction system design whereby air is forced through ducts in the front bumper to a horizontally-mounted intercooler.
Because FMIC systems require open bumper design for optimal performance, the entire system is vulnerable to debris. Some engineers choose other mount locations due to this reliability concern. FMICs can be located in front of or behind the radiator, depending on the heat dissipation needs of the engine.
As well as allowing a greater volume of air to be admitted to an engine, intercoolers have a key role in controlling the internal temperatures in a turbocharged engine. When fitted with a turbo (as with any form of supercharging), the engine's specific power is increased, leading to higher combustion and exhaust temperatures. The exhaust gases passing through the turbine section of the turbocharger are usually around 450 °C (840 °F), but can be as high as 1000 °C (1830 °F) under extreme conditions. This heat passes through the turbocharger unit and contributes to the heating of the air being compressed in the compressor section of the turbo. If left uncooled this hot air enters the engine, further increasing internal temperatures. This leads to a build up of heat that will eventually stabilise, but this may be at temperatures in excess of the engine's design limits- 'hot spots' at the piston crown or exhaust valve can cause warping or cracking of these components. This effect is especially found in modified or tuned engines running at very high specific power outputs. An efficient intercooler removes heat from the air in the induction system, preventing the cyclic heat build-up via the turbocharger, allowing higher power outputs to be achieved without damage. Compression by the turbocharger causes the intake air to heat up, rather than the air being heated by contact with the hot turbocharger itself, the vast majority is through the act of compression (ideal gas law) plus added heat due to compressor inefficiencies (adiabatic efficiency). The extra power obtained from forced induction is due to the extra air available to burn more fuel in each cylinder. This sometimes requires a lower compression ratio be used, to allow a wider mapping of ignition timing advance before detonation occurs (for a given fuel's octane rating). Although a lower compression ratio generally lowers combustion efficiency and costs power.
Air-To-Liquid Intercoolers
Air-to-liquid intercoolers (aka Charge-Air-Coolers) are heat exchangers that transfer intake charge heat to an intermediate fluid, usually water, which finally rejects heat to the air. These systems use radiators in other locations, usually due to space constraints, to reject unwanted heat, similar to an automotive radiator cooling system. Air-to-liquid intercoolers are usually heavier than their air-to-air counterparts due to additional components making up the system (water circulation pump, radiator, fluid, and plumbing). The Toyota Celica GT-Four had this system in the 1988-89 version and also in the Carlos Sainz RC Version.
A big advantage of the air-to-liquid setup is the lower overall pipe and intercooler length, which offers faster response (lowers turbo lag), giving peak boost faster than most front-mount intercooler setups. Some setups can use reservoirs that can have ice put into it for intake temperatures lower than ambient air, giving a big advantage (but of course, ice would need constant replacement).
Ford had adopted the technology when they decided to use forced induction (via Supercharger) on their Mustang Cobra and Ford Lightning truck platforms. It uses a water/glycol mixture intercooler inside the intake manifold, just under the supercharger, and has a long heat exchanger front mounted, all powered by a Bosch pump made for Ford. Ford still uses this technology today with their Shelby GT500.
Summary Of Intercooler Function
Air is pressurized by force induction, causing it to heat up. This hot air goes in the intercooler at one end, then flows through the high surface area vanes, causing heat to be lost through dissipation. The air then flows out the other end of the intercooler at a lower temperature and into the intake of the engine.
Intercoolers Explained
Started by 2LV8ETR, Oct 10 2009 04:30 PM
Posted 10 October 2009 - 04:30 PM
Posted 26 October 2009 - 11:46 PM
I had a read because I'm looking at getting a FMIC either this week or next I think, so that my car will have all the supporting mods ready for an ECU and tune hopefully soon.
Authentic Godzilla Performance (from SAU), Just Jap and a few other places can get me china intercooler kits for around the $400 mark. I could also spend a few more hundred and get something Jap like a Blitz or a Greddy intercooler. What sort of advantages will I see from a Jap core, is it reccommended?
Also if I spray my cooler black wil this hinder its performance. I obviously want a great performing FMIC but I also want to keep my black on black look I have with my car.
What do people think?
Posted 27 October 2009 - 08:03 AM
There's nothing majorly wrong with the cheaper IC's. The only issue with them is that I've heard that some can come with bad welding which could leak, but I've yet to come across an example of this.
Basically they are a heat exchanger and not a complex piece of equipment like a turbo so there's very little that can go wrong with them.
Cheap China parts are okay in some uses, and this is one of them.
As far as painting the IC black is concerned, I've also read through personal study that paint will retain the heatsoak. It's advised to have the IC anodised. In saying that though, GT-R IC's are painted black.
Posted 27 October 2009 - 07:45 PM
Posted 27 October 2009 - 08:04 PM
Posted 29 October 2009 - 10:56 PM
Looking at getting one this week or something. Blitz CS/Greddy M-Spec = $800, No-name = $400-$500. ARGH!
Posted 30 November 2009 - 09:12 PM
I have a blitz one and it seems good. Though I reckon it's just the brand name you want to associate with your car.
Why Drink and Drive when you can Drift and Slide.....
