that can drive you crazy. You can't even have the stereo on and have the door open while working outside without
beep, beep, beep, beep, Arrrggh !!!
So where does it hide ? Lets have a look.
1. Locate and remove the plastic phillips screw at the top of the dash surround.
2. There is a plastic bezel that comes out too.
3. Remove the dash surround. You will have to drop the steering column to its lowest height
4. 3 phillips screws hold the instrument cluster in, remove them.
5. Pull the instrument cluster out and flip it over. You will see a plug and two screws.
Unplug the harness and remove the two screws.
6. With the back cover removed we can see the little piezoelectric beeper.
It can be quietened by putting tape or bluetak over the hole. It can be removed by pliers easily too.
Fitment is the reverse of removal.
* The beeper is a warning device and modification is at your responsibility.
