I am listing this on behalf of my friend Steven in NSW. Irregardless of location this is a killer motor at a GREAT price.
For sale is the engine out of my R33, it was running 390rwkw with the below list of parts, add in a set of cams and you have yourself a 400kw capable package. I have receipts for most of the parts some have been lost over the years but i can supply a PDF of the ones i have upon request.
The engine is currently at an engine shop to be pulled down and checked out, if all is good it will have as minimum all bearings replaced when it is put back together, meaning you get effectively a brand new engine
The engine will be supplied complete with everything bolted on from throttle body to dump pipe, and sensors.
Parts list:
RB30 series 2 Block
R33 RB25DET head
Forged pistons (Arias 9.3:1 CR, oversize 86.5mm bore)
MLS 1.3mm Head gasket
Forged rods (Eagle with ARP bolts)
Grub screwed stock RB30 crank
Pro Engines extended oil pump drive
RB26 standard water pump
RB26 N1 Oil pump
Solid line External oil feed for VCT using T piece at the oil pressure sensor.
ARP main studs
ARP head studs
ETM steam pipe high mount exhaust manifold (ceramic coated)
Synchronic 50mm external waste gate (plumbed back into dump pipe)
ETM 4" Dump pipe reducing to 3.5” at exit
Garrett GT3582R 0.82 AR rear housing (rear housing has been ceramic coated)
Greddy Intake Plenum (genuine not a cheap ebay copy)
Q45 90mm Throttle body
Balanced pistons, rods, crank (to within 0.1 gram)
Stock cams with VCT retained
Aftermarket valve springs
Stock fuel rail
Nismo 740cc injectors
Stock fuel pressure regulator
exhaust side of head oil drain to sump
ASR 6.5L extended/baffled sump with additional -10 fittings (everything that returns oil to the sump has its own fitting, no T pieces or Y joins)
Yellow Jacket coil packs
4" intake pipe with pod filter
Ignitor, CAS other factory sensors/electronics
NISMO R33 engine mounts
Will not come with power steering pump, aircon compressor or harmonic balancer
Can be supplied with the alternator and spare stock coil packs if you wish
Asking $12,000.
Contact by phone/sms 0419302418
[NSW] FS: Forged RB25/30 Complete Engine
Started by Hank Scorpio, Jan 09 2013 07:18 AM
