Pair of 35mm hubcentric spacers, 5x114.3 12x1.25. imported from the USA, payed $220 for these. (suits most nissan's/toyota's/ford's) - only used for a week or two, they are a bit too thick for my wheels. very good condition $130
Screamer pipe, suit R33 GTS-t. straight rswapover with stock dump pipe. good condition $60
R33 GTS-t SII drivers side window switch unit. the drivers side switch doesnt work (mechanical not electrical), apart from that the other 3 switches work and is in good nic $70
Also selling a used set of HKS hipermax coilovers to suit R33GTS. the 2 fronts are fine, but the 2 rear ones need reconditiong. throw me an offer.
Prices are ONO
0423 597 293 - Luke. Located NOR.
Skyline bits
Started by landscribble, May 30 2011 10:08 PM
Posted 30 May 2011 - 10:08 PM
Posted 31 May 2011 - 10:21 AM
when you say the window switch unit, do u have the motor? i have a broken switch and stuffed motor
I'm not a complete idiot, some parts are missing
Posted 31 May 2011 - 06:28 PM
not the motor, the whole unit thats operating the 2 windows, window lock, and that other button, i forget its purpose.
yeh i kinda stuffed the switch while trying to mend it, so had to buy another 2nd hand one
Posted 31 May 2011 - 08:38 PM
Hows it broken? Maybe Mish could combine the two broken switches to get one working one? Otherwise yours isnt worth much at all.
Btw, the other button locks the doors.
Posted 31 May 2011 - 08:56 PM
The switch went from being all limp and intermittently working, to far too stiff and not working at all. i tried gluing this little broken plastic part together, inside the switch, which is what causes it to go limp. then made it worse somehow when i put it back together lol.
Posted 01 June 2011 - 07:00 AM
hahaha my switch is very stiff and i believe the cluster has water damage. but from what i can see i dont think i even have a window motor. i was fishing around in my door and found all the brackets but nothing was there
