Lexus LFA vs GTR35
Started by GreyWolf, Apr 25 2011 04:17 PM
Posted 25 April 2011 - 04:17 PM
LFA looks and sounds awesome but i reckon GTR35 FTW still
skyline... rex... skyline... rex... im starting to sense a pattern
Posted 25 April 2011 - 04:27 PM
Posted 25 April 2011 - 05:59 PM
Fuck all in that.
Buy the GT-R, drop $40k into it, smoke the LFA, then you've got $200k to buy a 32 GT-R and give it 1000hp.
You'll still have change to shout your mates to hookers and piss for a year.
Posted 26 April 2011 - 08:07 AM
Make the GTR light body weight like the LFA and then see who wins.
Posted 26 April 2011 - 10:06 AM
As of today only that means its
340,000.00 GBP=523,667.81 AUD
Posted 26 April 2011 - 10:15 AM
Lexus LFA
• A trio of sophisticated CFRP molding processes for an impressively low 3,263 lb (1480kg) curb weight – an estimated 220 lb (100kg) saving over an equivalent aluminum construction
Drivetrain
Brakes (F)Disc, Carbon Ceramic Material, cross-drilled and ventilatedBrakes ®Disc, Carbon Ceramic Material, cross-drilled and ventilated
Engine
Compression Ratio12.0:1 Bore X Stroke3.46 x 3.11 (88 x 79)Cylinders10-cylinders, 72° V-type
Engine & Transmission
Displacement cu in (cc):4805
Performance
Acceleration 0-60 mph s:3.6Max Torque: 354 lb-ft/480 Nm/48.9 kgf-m@6,800rpm
Nissan GTR Spec V
Body
Wheelbase2,780 mm
Chassis
Brakes (Front)Carbon-ceramic ventilated discs (390 mm)Brakes (Rear)Carbon-ceramic ventilated discs (380 mm)WheelsRays lightweight forged alloy wheelsTires Front255/40ZRF20Tires Rear285/35ZFR20Front SuspensionIndependent double wishboneRear SuspensionIndependent multi-link
Drivetrain
LayoutFront Engine, AWDTransmissionGR6 dual-clutch transmissionFinal Drive Ratio3.700:1
Engine
Type:VR38DETT V6 DOHC Twin-turboCompression Ratio9.00:1Bore X Stroke95.5mm x 88.4mm
Displacement cu in (cc):3799ccPower bhp (kW) at RPM:480 bhp @ 6400 rpmTorque lb-ft (Nm) at RPM:428 lb-ft. @ 3200 rpm
Exterior
Tires F-RBridgestone Potenza RE070R Runflat TiresBody Type2 Door, 2 Seat GT CoupeLength4,650 mmWidth1,895 mmHeight1,370 mmCurb Weight3704 lbs.Ground Clearance110 mm
Drivetrain
Engine
Performance
Nissan GTR Spec V
Body
Wheelbase2,780 mm
Chassis
Drivetrain
Engine
Exterior
Posted 26 April 2011 - 09:27 PM
