After being asked a million and one questions regarding what are the best mods to perform to an engine to get (x) amount of power, I have decided to post up real world examples of what modification people have done to their engines, and the power output of the result.
I will lock out this thread to keep out unwanted chatter as I intend on posting many examples to give you all an idea of what to expect if you were to proceed down a certain path.
If you want to discuss any of the examples here, go to the relevant forum for the vehicle type and post any questions in there if you want questions answered.
Engine Modification Examples
Started by 2LV8ETR, Mar 02 2011 03:11 PM
Posted 02 March 2011 - 03:11 PM
Posted 02 March 2011 - 03:23 PM
Owner: Chung
Car: 1995 Supra
Engine: 2JZ
Power Output: 747rwhp (557rwkW)
Block
Stock internals
Head
Stock
Induction
Garrett T51R turbo
HKS FMIC
3" pipe kit
2 x Blitz BOV's
Exhaust
C&D 3.5" turbo to cat, 3" cat back
38mm external wastegate
Electronics
APEXi Power FC ECU
APEXi AVCR EBC
APEXi RSM
Fuel
2 x Bosch 044 fuel pumps
Surge tank
800cc side feed injectors
Drivetrain
Stock gearbox
Exedy triple plate clutch
Other
Catch can
Car: 1995 Supra
Engine: 2JZ
Block
Stock internals
Head
Stock
Induction
Garrett T51R turbo
HKS FMIC
3" pipe kit
2 x Blitz BOV's
Exhaust
Electronics
APEXi Power FC ECU
APEXi AVCR EBC
APEXi RSM
Fuel
Surge tank
Drivetrain
Stock gearbox
Other
Catch can
Posted 02 March 2011 - 03:40 PM
Owner: Roy - WA
Car: S13
Engine: SR20DET VCT
Power Output: 430rwhp (321rwkW)
Block
Decked
Rebored 20 thou
Stock crank
Eagle rods
Arias forged pistons
Moly rings
ARP rod bolts
Modified factory oil pump
Front mount oil cooler
Trust sump
Oil baffle
Head
ARP head studs
Tomei metal head gasket
Tomei rocker stoppers
Tomei valve springs
Tomei adjustable cam gears
Tomei 260° 12mm lift cams
Induction
Modified Garrett GT25/T04B plain bearing turbo from Performanz
K&N filter
Hybrid FMIC
SR20DE throttle body
Greddy intake plenum
Exhaust
3" C-Red custom exhaust
45mm Turbosmart external wastegate
Custom mandrel bent Butler Built manifold
Electronics
Autronics SMC ECU with antilag
Fuel
740cc Nismo injectors
Bosch 044 fuel pump
Drivetrain
Stock 5 speed S14 gearbox
OS Giken twin plate clutch
RG 2200lb pressure plate
Lightened stock flywheel
4.3 Tomei locker diff
Other
Lightweight pulleys
RG radiator
1.3bar radiator cap
16" thermofan
Car: S13
Engine: SR20DET VCT
Block
Decked
Rebored 20 thou
Stock crank
Eagle rods
Moly rings
ARP rod bolts
Trust sump
Oil baffle
Head
ARP head studs
Tomei valve springs
Induction
K&N filter
Hybrid FMIC
Exhaust
Electronics
Fuel
Bosch 044 fuel pump
Drivetrain
Other
Lightweight pulleys
RG radiator
1.3bar radiator cap
16" thermofan
Posted 04 March 2011 - 11:01 PM
Owner: Sean Pereira - QLD
Car: R33 GT-R
Engine: RB26DETT
Power Output: 500awhp (373awkW)
Block
Fully balanced crank
Short pin conrods
ARP rod bolts
JE 88mm forged pistons
N1 oil pump
N1 water pump
HKS Oil cooler
Head
Ported & polished
HKS 280° cams
HKS Drag Pro valve springs
HKS adjustable cam pulleys
HKS 1.6mm metal head gasket
Induction
Twin Blitz K26 turbos
Blitz 120mm FMIC
Custom intake pipes
Exhaust
Twin Blitz wastegates
Custom dump pipes
Electronics
MoTec ECU
HKS EVC4 boost controller
Fuel
Custom fuel rail
700cc injectors
Twin Bosch pumps
Custom surge tank
Sard fuel regulator
Drivetrain
Car: R33 GT-R
Engine: RB26DETT
Block
Short pin conrods
ARP rod bolts
N1 oil pump
N1 water pump
HKS Oil cooler
Head
Ported & polished
HKS 280° cams
Induction
Blitz 120mm FMIC
Custom intake pipes
Exhaust
Custom dump pipes
Electronics
MoTec ECU
Fuel
Custom fuel rail
700cc injectors
Twin Bosch pumps
Custom surge tank
Sard fuel regulator
Drivetrain
Posted 16 March 2011 - 04:33 PM
Owner: Nigel Beale - VIC
Car: 1994 Supra
Engine: 2JZ-GTE
Power Output: 769rwhp (574rwkW)
Block
0.5mm oversize bores
0.5mm oversize JE forged pistons
Eagle H beam rods
Clevite bearings
Head
HKS 264° 9.25mm lift inlet cam
HKS 272° 9.35mm lift exhaust cam
Induction
2 x Trust TD06-20G turbos
Custom intake pipes
K&N pod filters
Trust 130mm FMIC
GT-R BRV's
Exhaust
50mm wastegate
Electronics
Autronic SMC ECU
MSD DIS-4 CDI
APEXi RSM
HKS EVC-4 boost controller
Fuel
Custom twin entry billet fuel rail
880cc Seimens injectors
APEXi FPR
Custom surge tank fed by upgraded in tank pump
Twin 10mm fuel feed lines
Single 10mm fuel return line
Drivetrain
VeilSide shifter
Car: 1994 Supra
Engine: 2JZ-GTE
Block
Eagle H beam rods
Clevite bearings
Head
Induction
Custom intake pipes
K&N pod filters
Trust 130mm FMIC
GT-R BRV's
Exhaust
50mm wastegate
Electronics
Autronic SMC ECU
MSD DIS-4 CDI
APEXi RSM
Fuel
APEXi FPR
Drivetrain
VeilSide shifter
Posted 16 March 2011 - 04:50 PM
Owner: Michael Pajor - SA
Car: 300ZX
Engine: VG30DETT
Power Output: 349rwhp (260rwkW)
Induction
Rebuilt stock turbos with T28 internals
2 x Trust IC cores on stock SMICs
2 x Blitz BOVs
Exhaust
Twin 3 inch mandrel bent exhaust
Electronics
Blitz ECU
Drivetrain
OS Giken triple plate clutch
Standard transmission with OS Giken cross gears
Car: 300ZX
Engine: VG30DETT
Induction
2 x Blitz BOVs
Exhaust
Electronics
Blitz ECU
Drivetrain
Posted 16 March 2011 - 04:58 PM
Owner: Guy - QLD
Car: DR30 RSX Skyline
Engine: FJ20ET
Power Output: 231rwhp (172kwkW)
Induction
APEXi IHI-RHC6 turbo
Blitz BOV
HKS pod filter
K&J 600x350x76mm tube & fin FMIC
Exhaust
Custom 3mm stainless manifold
3 inch turbo back exhaust
Custom dump pipe with screamer
Fuel
VL turbo fuel pump
Malpassi rising rate FPR
Drivetrain
RB30ET VL clutch
Engine: FJ20ET
Induction
Blitz BOV
HKS pod filter
Exhaust
Fuel
VL turbo fuel pump
Drivetrain
RB30ET VL clutch
Posted 03 April 2011 - 08:12 AM
Owner: Nobuteru Taniguchi- Japan
Car: S15 Silvia Spec-R
Engine:
Power Output: 380rwhp (285rwkW)
Head
HKS 256° exhaust & intake cams
HKS strengthened valve springs
Induction
GT-RS turbo
HKS actuator
HKS FMIC
HKS Super Power Flow intake
Z32 AFM
Exhaust
Auto Produce BOSS SS manifold
Auto Produce BOSS SS dump pipe
HKS titanium Hyper exhaust & muffler
Electronics
HKS EVC boost controller
Yashio Factory ECU
Fuel
Nismo 550cc injectors
R33 GT-R fuel pump
Drivetrain
ORC single plate clutch
Nismo SSS LSD 4.1
HKS five speed dog engagement gearbox
Other
Blitz oil cooler
Yashio Factory radiator
Engine:
Head
Induction
GT-RS turbo
HKS actuator
HKS FMIC
Z32 AFM
Exhaust
Electronics
Yashio Factory ECU
Fuel
R33 GT-R fuel pump
Drivetrain
Nismo SSS LSD 4.1
Other
Blitz oil cooler
Posted 03 April 2011 - 08:13 AM
Owner:
Car:
Engine:
Power Output: !!!rwhp (!!!rwkW)
Block
Head
Induction
Exhaust
Electronics
Fuel
Drivetrain
Other
Car:
Engine:
Block
Head
Induction
Exhaust
Electronics
Fuel
Drivetrain
Other
