really isnt possible to give u a real idea without seeing the car or atleast photos.
but your R33 basically sounds stock. i wouldnt waste my money on a tune for a stock car.
pic of engine bay is the only way to really know but, r33 stock injectors are purple, by green fuel rail im assuming u mean thats its a faded moldy greeny/gold colour which is stock.
can guarantee you wont have an aftermarket fuel rail if u have stock intake manifold.
heres a stock fuel rail with injectors that i prepared earlier..
the dark purple injectors in the rail are stock the ones.
pretty safe to say your car wont have cams if u dont even have aftermarket injectors or turbo.
it may idle lumpy depending on your timing.
before u spend your hard earned cash on a dyno tune:
first step
-see what ecu you have- upgrade -even one of those ebay mines chips will do -can get rid of speed limiter etc
-see what fuel pump you have- upgrade fuel pump to minimum bosche 040
go from there ^^
after u upgrade ur fuel pump and ecu everything after that ie injectors turbo etc is gonna cost u over $1000
