RB25DE Head
Started by 2LV8ETR, Oct 09 2010 09:03 PM
Posted 09 October 2010 - 09:03 PM
I have been chasing an NA RB25DE head for some time now, but I won't give up. Ask around if you know people who are in the game and see if you get a bite.
The head was used on the NA R32 Skyline and the A31 Cefiro.
Any help would be appreciated.
Posted 09 October 2010 - 09:48 PM
The R32 RB25DE has no VCT, doesn't it? Would a normal RB25 head with aftermarket camgears do the same thing?
Posted 10 October 2010 - 12:09 AM
theres only room for one rb30det around here
i know ur set on finding a rb25de off ye old r32 but yeah man i rekon u'll be waiting a while to find one and for a head which is 20+ years old u gotta laugh at the rediculous prices ppl ask for them.
u dont have to go down my road n shit, but i rekn u can have a freshend up det head welded n modded for same price/cheaper than a 25de
-also have heard horror stories of ppl buying r32 rb25 heads then turning out to be rb20 heads haha
Posted 11 October 2010 - 09:58 AM
RB26 Head
Posted 11 October 2010 - 01:01 PM
Posted 11 October 2010 - 04:31 PM
Who you calling a dickhead, fuck face.
Posted 11 October 2010 - 04:35 PM
RB25DET and RB26DETT head = rewiring, ECU, and other shit and expense.
RB25DE head = straight on with no fucking around or expense involved.
No brainer.
No brainer.
Posted 11 October 2010 - 04:46 PM
Meh... shes custom anyway so whats the difference. If it was me, i would still be using the 26 head. I wouldn't bother with the 25DE. By the time you find one, you could of had it wired up with using a 25det or 26dett head. I know its not the easiest straight forward approach, but i would still do it.
Anyways, thats just me and what i would do.
Posted 11 October 2010 - 05:00 PM
The 26 and the 25 valve sizes are the same. the 26 uses larger head bolts so the block needs to be drilled and tapped. Other things are involved such as the galleries, etc.
By the time I'm finished I would be adding $4k +/- $1k onto the build for absolutely fuck all gain. The 25 head will flow 600hp and that's more than enough for my needs.
The advantage of the 26 is sodium exhaust valves and solid lifters, but they would only be an advantage if I was chasing huge numbers, which I'm not. Even if I was, it would be cheaper to fit solid lifters and sodium valves than to pay for the other crap involved to make the 26 head work.
The money I would save by staying with the 25DE head would go towards a better turbo and other things.
Posted 12 October 2010 - 12:46 AM
keh!? 4k?
det head,
pay someone to weld oil gallery
drill hole under inlet cam
tap hole with a special to the max 1/8" bsp TTPT bottom tap i had 2 buy and is in my shed never to be used again (52 fkn dollars)
oil pressure sensor feed $65.40 including hose n fittings from enzed or $100+ for a braided line
$21.05 22mm (or 18mm) tee join for head to block/turbo -enzed again
away uuuuuuu go, i should have done it myself ay
bottom of head shud look like this
yo
det head,
yo
Posted 12 October 2010 - 01:42 AM
Posted 12 October 2010 - 08:29 AM
Cant wait till both cars are up and running so we can see who the winner of this argument is
Posted 12 October 2010 - 12:25 PM
yes yes, i still stand by my argument
have u considered just going rb25det? $1500 these days will make u 400hp with less torque
Posted 12 October 2010 - 03:24 PM
Posted 22 October 2010 - 01:32 PM
http://www.skylinesa...32-t339683.html
rb25de head from r32, but he has it attached to a forged rb25det block for $2200.. maybe he'll get desperate n sell the head seperate? wtf would u even have a de head on a 25det!?
Posted 22 October 2010 - 03:37 PM
So you can hook it straight up to the R32 loom without any modification.
Valve sizes are the same.
Posted 22 October 2010 - 03:39 PM
Posted 26 October 2010 - 01:03 AM
Posted 27 October 2010 - 04:17 PM
RB26 Head
Posted 27 October 2010 - 07:05 PM
