Got bored today so decided to install some LED strips into the Yaris just above the footwell. So when you unlock or open your doors it will light up.
Its a nice feature when your dome lights aren't bright enough.
A few items you will need:
wire
fuse holder + 10amp fuse
4 pin relay
4 spade connectors
ring terminal
LEDs or LED strips (EBAY is the cheapest)
wire strippers
crimper
soldering iron
solder
electrical tape
A diagram of which wires to connect to. YARIS ONLY (COROLLA MAY BE THE SAME PLUG)
I did not take photos of what i actually did.
Where the pink wire connects to, is the door lights. I think all Toyotas door/dome light is pink. If you're not sure just unplug the connector and your dome light should go out.
You can find this plug in your Body ECU. Generally behind the glove box in most Toyota's.
Current model hilux is under the steering wheel. If you can see the fuse INJ it is the 5 pin plug just above. Pink wire is Pin 4.
I know you can also put an LED to shine on to your key barrel with this method.
Enjoy!
