A31 Cefiro Restoration
35 replies to this topic
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
  • Car(s):Nissan Cefiro A31 ( x2 )
This is on just about every forum I use now :)
In Early 2009 I was looking at getting myself an import...I was put off being like the sheep, buying a pre built monster, I wanted to learn my car like my previous cars (FWD, auto's), having a soft spot for Cefiro's and the other rare sedans, I started looking around.
Initially had no luck, as you have to know where to look, but I ended up with several options. An ex drifter shell, a genuine Autech Edition, a few local ones, and this one that I bought. I twas the shittiest, and yet the best, and stood out, I snapped this up on an impulse, it has been a massive mistake, a massive learning curve, and yet the best car I've owned, it's taught me soo much, even though it isn't finished yet:
Factory setup was RB20DE Auto, but when I bought it off eBay from Queensland, it already had an R32 RB20DET setup, with a 5 speed manual swap.
Everything else was standard, even the exhaust. Had a K&N M's pod filter, a heavy duty clutch and a 2 way diff (stupidly bi-polar aggressive 2 way I will add).
It had been sprayed over with a 2 pak primer and ready for a new paint job, which it never received. It had minor faults, like an exhaust leak, cracked windshield, bald tyres, and needed a tidy up. It wasn't registered, and hadn't been for a few years, for me this seemed like the ideal first car, I knew by the time I go this on the road I wouldn't destroy it.
Paid for it on May 17, it left Queensland on May 19, and arrived on June 2nd
Once it arrived, I put all the external trims back on (as seen in above photo's) and got to work. Once I did get stuck in I got carried away being a perfectionist. Little problems got bigger, I pulled it apart further, and it started getting messy.
Exhaust leak ended up being the far back top row exhaust stud snapped off INSIDE the block (about 5-10mm in) which was a little wanker to get out.
CEVA who transported the car from Queensland to here, obviously didn't take into consideration the low ride height of the vehicle, hence the chassis rails were rooted. Cracked windshield had become a billion times worse.
Also the car was nowhere near what I thought I payed for.
Eletrical problems from front to back.
Mexican style rewiring which eventually resulted in the overheating and subsequent death of the ECU and sub looms.
Interior and exterior trims missing
Horn not wired up
You get the idea
Between that and everyone's negativity, I eventually threw in the towel, attempted to sell it, and luckily nobody did, I dived back in, and no suprise, confronted with more problems...but I kept a level head about it...well, tried to.
The next big problem, was brakes....sitting in the driver's seat writing a message on my phone one day, just stuffing around with the pedals, and the brake pedal goes all the way down, and slowly returned back up, brake fluid running down the firewall...so that was the master cylinder and/or booster, gone, rather than chuck the shits, I decided to do an all round brake upgrade (since I needed to bleed fluid anyway), and snapped up an complete R33 package
4 piston front calipers w/ 296mm rotors
2 piston rear calipers w/ 297mm rotors
Booster
Master cylinder
Lines
Comparison of factory brakes (left) and new brakes (right) after a quick respray in black
(these are currently AGAIN disassembled for sandblasting and anodizing, stay tuned for progress)
The next parts are somewhat useless,
Since I'm paid monthly, I spend alot of time waiting for money, or parts, so boredom kicks in.
I took the manifolds off, for a quick coat in high temp black:
Crossover pipe:
Again, got carried away, did the engine bay as well
Firewall, with new booster
And the insides of the doors and shit (helps reduce cost of paint job when time comes)
I also got stuck into the eletrical problems inside
Scraped the interior, in favor of an optional black interior I found
It's hard to stay motivated when you have a billion pieces of no car, and a small shed
Ordered HST TT Coilovers
5 Stud hubs
Monkey Warehouse kit
And some of these:
Then got stuck into suspension, replacing every bush from front to back, with Nolathane items
Again, it's hard to stay focused on the bigger picture when the bare shell is on axle stands, no cradles, no motor, box, driveshafts, and no interior
Eventually got the front back up, with the coilovers and hubs on, and I CAN SEE THE LIGHT
On a cleaned crossmmeber, here's a pic I managed to take half way done cleaning (hands were too dirty to take a finished product pic)
And the finish:
That's about where I'm at now:
Currently in the works:
Chassis rail repair
Saving for paint
Saving for Origin DNA-01s (PIC
It's been slow lately as I've been shifting my attention to my other Cefiro (about to make that one it's own thread as well)
Will keep this updated, so stay tuned.
Comments, positive and negative, welcome :)
Tritty
Tritty
  • Secretary
  • 750 posts
  • Real Name:Marianne
  • LocationKenwick WA
  • Car(s):R32 GTR, HB Torana SL Series 2 (Project), GQ Patrol
nice job! Cant wait to see the finished project.
Its the little things in life that count.
Coming along nicely Nic.
Is this the same car we were talking about a couple of years ago with the meetings about the hoon laws?
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
Thanks Tritty.
Alan, yeah that's the one, it wouldn't have been that long ago, I only bought it May last year, but yeah, same car, at the time I only had this one.
Mally
Mally
  • Paid Member
  • 512 posts
  • Real Name:malcolm
  • Locationmalaga area
  • Car(s):76 statesman, 09 colt
Sounds like your learning alot... i wouldnt mind one of these. but if i did, id be throwing a 350 chev in :P
I love these builds, and Ceffies are easily the sexiest cars on the roads! I'll be watching this space eagerly :)
Great work so far!
Fuck, it felt like a long time ago.
Heatseeker
Heatseeker
    Mitsubishi Lancer Evo
  • Guest Member
  • 87 posts
  • Real Name:Rob
  • LocationPerth
  • Car(s):04 Ba Falcon, 91 EB XR8 347 Stroker, WB 1 Tonner
Looks like your doing very well with it mate, just keep up the good work, and she'll shine when shes done!
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
Probably going on the other Cefiro, as this one is empty and most of the 20DET is long gone
Would that fit on the 25 tho? You've got some skills with the can! I gott do my rocker covers and engine highlights, but I'm not too good with painting :(
Lol that sort of stuff is so ridiculously easy Rhys. You sound like James :P
I'll pull a motor out with ease, but fucked if I can use a spray can!! Lol
1 trolley jack + 1 jack stand - i hope u dont plan on getting underneath that
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
It's in the shed now, on 4 stands :P
Safety first!! That reminds me, I need to buy 4 stands and a trolly jack. I'm still using a scissor jack and a tyre :confused:
all mine are under my skyline -just bought 2 more.
few months back under necessity got under a honda using scisor jack, time to pack up and notice the scissor jack is actually bent, was bout to fall apart and kill me. good times
come talk to me about being payed monthly and also losing motivation, my car has been off the road since december yet only think its been 2 months! haha best thing to do is try set a date for when it'll be ready
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
This one hasn't been driven since late July 2009 :'(
Have you ever properly driven it since you bought it?
Nic_A31
Nic_A31
  • Paid Member
  • 280 posts
  • Real Name:Nic
  • LocationSwan View
Sort of.
The day it arrived, I did maybe 5km, I did a few laps of block every night to keep the battery charged up and see what difference the shit I was doing made to it.
Did an impressive skid for a particularly good looking blonde neighbor, at the cost of being 100 metres away from a marked cop car that followed me around the corner and up to my driveway, then drove off, (yeah, dunno, I didn't have plates on, they didn't even look at me when they drove past) after that, the usual laps a few more times, then yeah, eventually came off the road permanently.
Driven it no more than 20kms...but the amount of shit I've changed, it's a whole new car anyway. Every suspension part, and bush, has been replaced, motor and box will be different, etc. Have to learn all over again.
