With the Wolf you won't need the AFM's.Wolf3D v5 ECU, Z32 AFM's.
Nismo or Sard injectors. Sard's will most likely need a spacer, but that's neither here nor there. Depending of course what fuel rail you'll be using.Heres something, what injectors, cams and cams gears does everyone recommend? Ive herd HKS cam gears are bad for slipping. I don't want that happening. JUN/Tomei?
Cams - Jun Stage 2R $$$$$$ (comes with gears), Tomei or HKS in second place. Also lift & duration will vary depending on power figures.
I've too heard of HKS cam gears slipping. Then again, a lot of people are using them with excellent results. Nitto's are supposed to be good but pricey.
Not my opinon. I reckon the wastegates were cracking open. I believe the Le Mans turbos you have to put on come with heavier springs. That's why big power turbos use an external gate.BTW the jumping on the HP figure i reckon was because it was jumping on the dyno but i could be wrong.
